Originally Posted by _paralyzed_
if landing a jump is shutting it off then its a switch position problem, not a switch problem. moving the switch would cure your problem.
I believe the switch should be mounted in the esc case. There are enough things to mount, and enough wires.
The impact of landing flipped the switch off... And Eovnu's car has the swtich mounted laid down. and hard landings flip it off too.
orientation doesnt change it.
