Thread: Spyder diffs
squeeforever
squeeforever's Avatar
12.18.2005, 01:01 PM
your going to need the plastic second speed gear, the output shaft, the input shaft (modified for the single speed), the idler shaft, and mikes idler, strobe slipper, plastic or derilin ofna spur, stock pressure plates, and i would recommend the sprong kit. you will need all of that and then your flm cnc'd half and the singlespeed conversion. i think thats all for the tranny. not sure what motor mount you wanna run but theres a few better than stock.
