riverat1540
riverat1540's Avatar
04.22.2009, 07:37 PM
u also need to know if the 2.5 is the inner diameter of the pipe or the outer diameter. if they are the same u can just connect them with band clamps but if the pipe on ur truck will fit over the glass pack that is the way to go and u can get a better fit less likely to leak, also if the old muffler is off set u will have problems with the fit. before u go cutting up ur old stuff besure u have a strait shot between the pipes after u cut the muffler out.
Losi Muggy
medusa 36-80-2000kv
6s turnigy 30c
MMMV3
46ts/ 14-16p
spektrum radio
  Send a message via Yahoo to riverat1540 Send a message via AIM to riverat1540
