littlegiant
04.23.2009, 06:51 AM
Originally Posted by himalaya View Post
efficiency is a function to amperage, not velocity, as long as you gear it correctly to keep it working under right current region(40~70 amps most time), the efficiency would be just fine.
Neu, Castle and Medusa are all rated at 60k rpm.
Every motor has a certain range of RPM at which it will run at its max efficiency.
