04.23.2009, 12:03 PM
Our local track is being finished off this weekend. Once I'm on my home turf, I plan to tweak the handling. The only change I did make was to go with the purple springs in the back and set the ride hight accordingly. With the Electric goodies it's about .3-.5 pounds heavier than a Nitro so I needed quite a bit of pre-load adjustment in the front and rear. I also plan to go with the 3/3 clip in the back. Stock is 3/3.5 and I've heard it makes a difference, not sure if that's true but for $12 I'm going to give it a shot. Finally I run the battery as close to the front as possible. I'll continue to post as I find setup changes that help handling.
