Pdelcast
Pdelcast's Avatar
04.23.2009, 06:43 PM
I just wanted to be clear for Castle I was never an offiicial "tester" of the motors. I recieved them in exchange for the 20+ T shirts I designed and sent over the Castle - I did provide some feedback on the them mainly temps and the play in the rotor.
I've got probably got the only 2650kv HPI version around as I never got sent the production version...
PS Let me know when you get that crawler setup - There is a big NJ scene you should come along...
Well, if I was in charge of the MM Pro beta test, you would have one.
The MM Pro is (in essence) 2/3 of a MMM... they share almost the same design -- except for:
The MM Pro has sensor input (and some cool stuff, like CHEAT* mode)
The MM Pro has adjustable BEC output voltage (.1V increment adjust from 5.0V - 7.0V)
The MM Pro has a much smaller footprint
The MM Pro has a smaller fan (25mm) that can be removed (For BrianG)
*Castle High Energy Advanced Timing -- gives a power boost for stock type sensored motors, with adjustable lead-in RPM
Patrick del Castillo
President, Principle Engineer
