Originally Posted by Pdelcast
Well, if I was in charge of the MM Pro beta test, you would have one.
The MM Pro is (in essence) 2/3 of a MMM... they share almost the same design -- except for:
The MM Pro has sensor input (and some cool stuff, like CHEAT* mode)
The MM Pro has adjustable BEC output voltage (.1V increment adjust from 5.0V - 7.0V)
The MM Pro has a much smaller footprint
The MM Pro has a smaller fan (25mm) that can be removed (For BrianG)
*Castle High Energy Advanced Timing -- gives a power boost for stock type sensored motors, with adjustable lead-in RPM
where i can buy this beast
