Originally Posted by snauty
Hey if you were to do 2 2s 4000 mah batteries. Will that lower the discharge rate or will it stay the same.
If you are running one 4000mah 2s pack at a time, the discharge rate will be much lower then when it was an 8000mah pack. If you run two 4000mah packs in a parralel you'll have the same as it was originally....
Remember you have 6 cells...
