Thread: ezrun 150A
jsr
04.24.2009, 09:09 PM
Start with default settings and see how it runs. You do not need to adjust timing as delta-wound motors are insensitive to timing changes. Do NOT adjust punch to "0". I wouldn't go below "3". Set your Low Voltage Cutoff for LiPos if you use them. Aside from that, you're fine.
