04.26.2009, 01:06 AM
You have the motor already and it's a good/expensive one. So, I would suggest doing what you can to use it. First, gear down (12-13T pinion). That alone will slow the setup down. Then, to tame the immense torque from such a low gearing, turn the punch control wayyy up.
