04.26.2009, 01:22 PM
Funnily enough... I do.
Depends where you go to get one, since most stuff in the UK tends to be imported from the orient or the states, so prices are higher for the same item compared to what they cost abroad. That said, if you want a do-it-all charger that is simple to use and doesnt cost a fortune, you have a few choices:
Hyperion 606i
Bantam BC6 (I have one of these)
These have a built in 12v power supply so you dont have to find a seperate one and hook it up; the only downside is it limits the charge power so something like a 5000mah 4s lipo will take about 1.5hrs instead of the usual 1hr. Thats not an issue for me personally but some people like a really quick turn around time so they can get out and bash their truck again asap.
I would google for the best prices- the bc6 is much more common in the UK (~£120), but the hyperion may be hard to find so importing would be your best option. This assumes you want a lipo capable charger and not just a nimh charger, but it makes more sense to get a better charger now rather than spend more £ upgrading later.
