Pdelcast
Pdelcast's Avatar
04.28.2009, 06:20 PM
Originally Posted by Unsullied_Spy View Post
As much as I'd hate to see the MM go, I think you're right. The MM is tougher to make than most ESCs (which is part of the cost, unless they re-design it to be cheaper to build). It's pretty much the most robust and reliable ESC on the market. I've had 6 or 7 of them and they are worth every cent. If they could make them cheaper to build but not sacrifice any reliability or specs (maybe drop in new FETs that are better than the ones that are in it) that would be incredible.
MM is still going to be available for the foreseeable future. MM Pro is adding to the line, not replacing the MM.
Patrick del Castillo
President, Principle Engineer
