Hopefully you haven't updated it yet. I am looking for the Losi MRC ratios right now...
Edit: Copy and pasted from RC-Driver:
The internal transmission ratio is 7.59:1. With the stock 60 tooth spur gear and 14 tooth pinion, the transmission has an overall ratio of 32.5:1. The ring and pinion in each axle have a ratio of about 2.64:1. This gives the Mini Rock Crawler an overall ratio of 85.96:1.
