Originally Posted by BrianG
OK, I really don't want to download the PDF and figure this out. So could you list all the gears used for each speed?
LST 1st gear: ?
LST 2nd gear: ?
List the gear pairs like so: output/input, output/input, etc. Similar to how I have the revo tranny listed in the calc. That would be the most helpful to make sure I have the right data.
And yeah, I'll add the Mod1.5
Ok lets start with the external 2 speed. Not sure if you will add that info (guess the spur sizes could go in the "spur section" under Lst)?
1st - 70/18
2nd - 63/25
Now here are the internal ratios:
LST FOC (this is the losi kit, also the internals of the aftershock are the same as this) - 23/22 primary 30/15 secondary
The Lst and Lst2 have a manually selectable high/low internal gearing, all other lst based trucks have the FOC listed above.
Lst/Lst2 low range internal gearing - 30/15 primary 30/15 secondary
Lst/Lst2 high range internal gearing - 23/22 primary 30/15 secondary
Also your "swap mod" info is correct.
I am sure no one care about the ratios for the mech reverse, so I will not bother looking them up.
