04.28.2009, 09:16 PM
Can you dial out throttle speed on your transmitter?
If you can- problem solved.
The best you could do short of setting the EPA is increase the ESC punch control to 100%, and maybe decrease the timing to lowest. 100% punch control makes for a very driveable setup, you just don't have that wheelie-popping torque. You could also change the throttle curve to be more gentle off the line either in the ESC or the radio (via exponential setting if it has it).
