Originally Posted by lincpimp
Since you have the equipment I would try both. The medusa with that gearing should be fine, not sure how well the neu will like the taller gearing. It is a 1515 so it does have more torque than the medusa so it may work fine. Report back with your findings, as I am interested to see what will work better.
OK,tomorrow I am going to test the medusa with 13/46, I run it before with 15/46 and it run well.... the motor run about 145ºf and the esc about 130ºf.... but it was very fast....... Tomorrow post result......
regards
