tonkabilly
05.01.2009, 11:39 AM
Don't think it was a binding problem. Just replaced both diffs as it blew one on first try. Took them apart again last night after the shaft broke and all is good. Can't say for sure if something got caught in the gears. Was only running around in the yard on grass. I set the mesh the same as I do for my nitro's. Has a little bit of play between the gears but maybe was a little tight?
What's better to use as a spur? Steel or plastic. I chewed a stock spur within seconds, that's why I went to the steel one. Just got a response from Medusa. They said they will replace the motor free of charge.
