jalodo56
05.02.2009, 04:48 PM
I can do these configurations for my buggy:
Medusa 2000kv: 13/46 whit it gear it go 160ºf fast
Differential Ratio: 3.3076923076923075
Transmission Ratio: 1
Other Ratio: 1
Spur Tooth Count: 46
Pinion Tooth Count: 13
Total Voltage: 18.5
Motor KV: 2000
Tire Diameter (inches): 4.5
Tire Ballooning (inches): 0
Motor Current Draw: 0
Motor coil Ω: 0
Spur/Pinion Ratio: 3.54 : 1
Total Ratio: 11.70414 : 1
Tire Circumference (inches): 14.14 inches (359.08 mm)
Total Motor Speed: 37000 RPM
Vehicle Speed: 42.32 mph (67.98 km/h)
Effective KV Value: 2000
15/46 with it gear it go 160ºf after 10min
Other Ratio: 1
Pinion Tooth Count: 15
Total Voltage: 18.5
Motor KV: 2000
Motor coil Ω: 0
Spur/Pinion Ratio: 3.07 : 1
Total Ratio: 10.14359 : 1
Vehicle Speed: 48.83 mph (78.44 km/h)
17/46 I do not know how it run
Other Ratio: 1
Pinion Tooth Count: 17
Total Voltage: 18.5
Motor KV: 2000
Motor coil Ω: 0
Spur/Pinion Ratio: 2.71 : 1
Total Ratio: 8.95023 : 1
Vehicle Speed: 55.34 mph (88.9 km/h)
NEU 1515 3d
Other Ratio: 1
Total Voltage: 18.5
Motor KV: 1360
Motor coil Ω: 0.012
Total Motor Speed: 25160 RPM
Vehicle Speed: 37.63 mph (60.45 km/h)
Effective KV Value: 1360
19/46 it get 158ºf after 20 minutes, it motor have a very good runtime.
Other Ratio: 1
Pinion Tooth Count: 19
Total Voltage: 18.5
Motor KV: 1360
Motor coil Ω: 0.012
Spur/Pinion Ratio: 2.42 : 1
Total Ratio: 8.0081 : 1
Vehicle Speed: 42.06 mph (67.56 km/h)
Neu 1515 2.5d
15/46 I do not know how it run
Other Ratio: 1
Total Voltage: 18.5
Motor KV: 1650
Motor coil Ω: 0.01
Total Motor Speed: 30525 RPM
Vehicle Speed: 40.29 mph (64.71 km/h)
Effective KV Value: 1650
Other Ratio: 1
Total Voltage: 18.5
Motor KV: 1650
Motor coil Ω: 0
Vehicle Speed: 45.66 mph (73.34 km/h)
19/46 I do not know how it run
Other Ratio: 1
Total Voltage: 18.5
Motor KV: 1650
Motor coil Ω: 0
Vehicle Speed: 51.03 mph (81.97 km/h)
what motor I need to use in my buggy???? and what gear????
