Originally Posted by Sylvester
+1
those screws might cause a ton of friction which will heat up your drivetrain some, o-rings would be the best solution.
I was thinking about the excess vibration it may cause too... would simple rubber/foam inserts work by having them push out on to the shaft?
Alien
