Thread: Lipo questions
Metallover
RC-Monster Spudgunner
Metallover's Avatar
05.04.2009, 09:47 PM
If you have some crazy capacity like 8000mah then the c rating isn't too important. If you're running 4s with a fiegao I'm guessing you arent going too much higher then 70-80 amps. If you upgrade the motor then you might be pushing it depending on the motor and the motor's kv. In the future I would recommend as much of a c rating as you can afford.
