MetalMan
MetalMan's Avatar
12.20.2005, 07:44 PM
Originally posted by Re~Mix
I will also probably start without a slipper, but i have found a few slippers out there, gs st1/dominator although they are very expensive. As of now, having enough trouble rebuilding the car.
If you will go with a slipper, I may be able to rig one up for you that uses popular Monster GT spur gears (mod1) or Revo gears. It is based off of the Revo slipper clutch, but is modified for 1/8 buggy use. I run one, and soon E-Traxxer will too (as soon as I get it built). The only problem would be with the bearings, as the shaft has a 6mm diameter. It might be worthwhile for me to look into some adapters to allow larger inner diameter bearings (larger than 6mm).
