TexasSP
Something, anything, nothing
TexasSP's Avatar
05.07.2009, 12:27 AM
Originally Posted by Aceldama View Post
The Tekin system is expensive, no question about it. But at least they're offering a true 6s solution with their combos. If you want a properly rated KV motor for 6s with the MMM you either get a Medusa (non sealed, pressed endbell) or buck up for a real Neu which makes it even more expensive than the Tekin combo.
So am I to understand that you have actually tried the 2200 CC motor yourself and this is from your personal experience?
Or is this just what you heard?
Based on what I have seen Patrick say the motor was set to be what is the most efficient setup and you change the voltage and/or programming to suit your needs.
www.cubicle101.com
