lutach
lutach's Avatar
05.07.2009, 11:25 AM
Originally Posted by Cain View Post
So, if the SP ESC is basically the guts of the 80amp unit that RCM sells, where can you get the outer case? What exactly is different between the two?
You could get it from Schumacher, but if you look at the Speed Passion site, it's just an aluminum piece that was added on. It looks cool, but you don't need it since it will add more weight to what seems to be a bigger ESC then the Mamba Monster.
