Originally Posted by lincpimp
Was the voltage over 3v per cell (6v) when you put the lipo on the charger? I do not use the auto lipo feature, as I do not trust it, plus I like to have a 3.2v per cell setting to protect the lipos should they go out of balance. I am guessing that you do not have a castle link? I would cough up the 20 bucks and get one. What you described sounds like the lvc cutting power.
Uhh, I think the voltage was still over 7v when I put the battery on the charger, but I forgot to take a look at it. No I don't have the castle link, im flat broke right now.
And Castle is charging $25 for them, unless you know of another place.
Someone here stated that once you remove the batteries from a load, the voltage jumps up a bit.
