05.09.2009, 07:46 PM
Originally Posted by Freezebyte View Post
Uhh, I think the voltage was still over 7v when I put the battery on the charger, but I forgot to take a look at it. No I don't have the castle link, im flat broke right now. And Castle is charging $25 for them, unless you know of another place.
Someone here stated that once you remove the batteries from a load, the voltage jumps up a bit.
Yeah, the lipos will recover voltage a bit after they sit. Sounds like you are ok. Did the MMM make 4 beeps when you switched it on? It should do its arming tone, then beep 4 times (to indicate 4 cells) if you have the auto lipo set correctly. It is a shame that hpi did not include a castle link with the flux...
