TexasSP
Something, anything, nothing
TexasSP's Avatar
05.09.2009, 10:08 PM
Originally Posted by Freezebyte View Post
I guess im confused, is voltage not directly related to mAh capacity?
Yes and no. AS the MAH drops the voltage drops. Putting almost 6000 mah back into a 6000 mah pack is not an issue. You mainly want to know what the voltage is per cell when it stops. If you are below 6v on a 2s pack I would be a little concerned.
Just to give you a quick example for reassurance I have my LVC set at 3.1 volts per cell. When I hit the cutoff on my 3s packs and put them on the charge they usually read 9.6 volts. It also routinely puts almost 5350 mah back into my 5350 mah pack.
As well as voltage if you start putting well over 6000 mah back into those packs I would be concerned. While the voltage may read over 6 the cells could well be out of balance which is critical as well. However seeing as you have a blancer and a good charger, I think you are well in the clear. This was just more an FYI type thing.
Last thing to note is that it is obvious you are using quality cells, which is another major factor. If these were maxamps or some other brand known to be lesser quality you may would have room for some concern.
www.cubicle101.com
