SpeedAssault
SpeedAssault's Avatar
05.12.2009, 03:40 PM
Nice looking adapter! I had a piece of sch 80 turned down to match the large ID on the bulk. And then had it paired off to the correct width. I did not bother to make the little step like you did, as I saw no need for it. Modding the front pinion support takes a bit of work, you need to turn the inside out to the OD of the nose of the lst case, then clearance the back of the collar to get it to fit against the lst case.
hey thanks lincpimp, -what does that mean?
Yea , I thought I took pics, guess not. I did forget to mention I did use a dremel to enlarge the inside of the collar, then a file to even it up.
I also like the sectioned lst driveshafts. I see that you sleeved them, did you also weld it too?
Yea once I make my CD / motor mounts I will decide on length needed for the front and rear shafts, Then Weld them
