05.12.2009, 03:47 PM
hey thanks lincpimp, -what does that mean?
Yea , I thought I took pics, guess not. I did forget to mention I did use a dremel to enlarge the inside of the collar, then a file to even it up.
Yea once I make my CD / motor mounts I will decide on length needed for the front and rear shafts, Then Weld them
Sounds like a good idea on the center driveshafts. The pipe I found had the correct ID, so all I had to do was turn the outside down to the correct OD.
lincpimp came from a bunch of us picking up chicks with an old lincoln towncar that I used to own.
