MetalMan
MetalMan's Avatar
05.12.2009, 05:08 PM
Finally, what many have been waiting for! It's still not done and has a fair bit more work required, but the rest is pretty easy and should go quick once I start. But much of the remainder is dependent upon the proper length front belt, which I just ordered and probably won't be here for another week... Anyways:
Lower belt guide:
Inside front diff case:
Upper belt guide:
Belt clearance with lower arm mount (note there is actually less clearance when the belt isn't lifted up):
Complete front end:
Belt protrusion below front bulkhead:
Mounted front end:
Rear end gear reduction:
Bottom of rear end (minus suspension plate):
