MetalMan
MetalMan's Avatar
05.12.2009, 05:08 PM
Lower suspension mount:
Back of rear end showing sway bar mounting:
Front of rear end:
Bottom of rear end:
Rear end mounted:
Check out all those screws holding the rear end on! Normally only 4 screws have that job...
And of course the motor/reduction unit:
Positioning:
The pics of the center unit are older, it will actually have the polycarbonate mounting piece directly behind the motor (and the gear will be behind it) so that the entire unit will fit on the chassis.
