lipo battery opinion -
05.12.2009, 06:45 PM
If you have a 1515 2200 kv running on 6S on an Lst2 with a 8k 6S M.A. and it doesn't even get warm it should be good correct as it's not getting overdischarge right? Can you guys give some input on these as I need to know if this was the cause of my ESC Hydra 240 failure with a 1527 1D 2300 kv motor lighting up my ESC on fire. The batts barely even gets warm at the time. Thanks in advance.
