brushlessboy16
brushlessboy16's Avatar
05.12.2009, 08:28 PM
So I spend a few hours toying with way to release my batteries a bit faster.. Came up with this..
I used some 3/16 kydex plastic. some angle aluminum stock and 2 quick disconnect throttle cable connectors that I found in our race trailer... It was entirely by accident but was a "Eureka!" moment.
(Connectors)
To take the Battery straps off- you simply slide the locking collar back 1/4in and the entire thing comes off- the opposite side attaches with just a slot that fits under a cap head m4 screw.
The studs for the quick disconnect were 10-32 So i had to drill and tap one hole on each of my novak battery trays- no Big deal.
Then Mounted the Female quick disconnect to a strip of angle aluminum using a m6 button head screw(I was surprised that they are metric from the factory) and mounted the other side of the aluminum to the kydex strip with 2 countersunk M3 screws for a flush underside.
My next task is to somhow spring load the bottom of th packs so they pop up when you take the straps off for easier removal.
Let me know what you think
