Originally Posted by MetalMan
If I had room for a band saw, I'd have a mill by now  . Aw, only 5s
This is just a small truck... It will do fine with the 5s setup. Now the 5th scale savvy will have 10-12s and a 1527. I am also going to 10s and a 1521 in the 6x6 lst, and the baja will run 2 big motors on a 10s setup... That should be enough high voltage setups. I also have 2 mega 1100kv motors, and an aveox 36/38/2y, and a 10xl kb 45. So all I need are a few more hv escs and I will be good to go!
