05.13.2009, 04:36 PM
Nothing a sandblaster can't handle!
Thats about the best method to remove paint from thick metal. It does leave a slight texture on the metal. It may show thru the paint, so if you do not want that sand the chassis after you sandblast with 400 grit paper till it is smooth. You may also want to buy an etching primer that you can sand, that will make the final coat smoother as well. If you do plan to sand the primer you can skip sanding the chassis after you sandblast it.
