05.14.2009, 12:53 AM
Originally Posted by BlackedOutREVO View Post
Thats sweet! I want that savvy!
Batt up front to cut down wheelies, should be a nice setup when its done!
Thanks, I may sell it...
The forward placement of the batt makes wheelies more controllable, found that with the last savvy I did and the lst. I plan to run a wheely bar (the single wheel setup from hpi). The main difference I find is jumping benefits most from forward battery placement. You can jump at close to full throttle without having to back off much or brake to keep the nose down. The added weight up front helps to counteract the bigger truck wheels/tires spinning unloaded.
