05.14.2009, 12:59 AM
Smart! I will prolly try that! What are the guys running mega power doing? Does anybody make an upgrade?
I used a drill bit shank, that is m2 steel and quite a bit stronger than the stock roll pin. Just find a bit that will be a press fit, cut it a bit longer than needed and press it in with a bench vise. You can grind on end to a cone shape (semi point) to get it to line up easier.
