XXXDAD
XXXDAD's Avatar
Exclamation 05.14.2009, 10:03 AM
The Losi doesn't require any shimming between the bulks - it is a drop in fit. With the losi conversion, the entire center diff assembly needs to be spaced up about 1 mm to allow the spur to clear the chassis, but no other mods are required. :)
Ok I see thanks for the lightning quick reply! I'm saving to get one....
Glenn Carlson
XXX-CR
XX-4 WED
8IGHT E
TEN SCT
Losi everything!!
