stum
05.14.2009, 11:38 AM
Maybe have a eflight connector on a swivel on one end of the battery tray (allows some movement) and then figure out a way to have the female be part of the battery pack (solid). This would let you insert it drop it into position quickly, then just a xross bar to hold in place, also just as fast removing. Obviously in all of these scenarios you need to have identical packs all setup the same way (size voltage etc)
