Since I will never use this ERBE in water, I decided to modify the receiver box to help get more room to pivot the motor to change the pinion or spur without removing it. I sanded off the portion of the receiver box where the wires go in.
I am now left with two large openings that I will block with a piece of closed cell foam glued to the box with CA glue.
Here is the foam glued to the box to block those openings.
A tiny hole in the foam for the receiver antenna to go through.
And a small slot for the wires to go in the box. The foam wraps around the wires and will keep dirt and dust from coming inside the box. Here is just an extension wire to demonstrate.
I can now pivot the motor far enough to change my pinion or spur gear without removing the motor completely.
HOP UPS
PUSHRODS AND TURNBUCKLES
I am using the Traxxas aluminum red pushrods and Traxxas aluminum red turnbuckles. I would rather have them black but the black pushrods are not out yet. I changed to Traxxas red pushrod spacers since the ERBE came with blue ones. I also like to use the TRA5348 turnbuckle rod ends on all the turnbuckles and the pushrods. They are the biggest and bulkiest rod ends used on the Revos. They are usually used only on the rear turnbuckles but I like to use them everywhere. You can recognize them by the small ring around the base of the ball end.
SHOCKS
Variable damping #3 shock pistons will be used on this ERBE, the rebound holes have been enlarged to 2 mm. I like a fast rebound. I will use black rear springs and gold front springs.
