Thread
My e-revo brushless edition build
11
mistercrash
Guelph, Canada, eh!
05.15.2009, 09:52 AM
DUBRO PROP BALANCER TO BALANCE MONSTER TRUCK WHEELS AND TIRES
I used the original base as a template to make the holes in a 150 mm X 80 mm plate of aluminum. The two pairs of holes are spread apart 120 mm.
This is the rod that goes through the wheel. It comes with two coned shaped pieces. I added an old Maximizer 17 mm hex, a tube of plastic as a spacer and a collar with a set screw.
And this is a sequence of pics on how I assemble a wheel on the shaft in case you haven't figured it out by the pics above already.
LIPO BOX
I read that a .50 caliber AMO can from the army surplus is just right to store lipos. It’s water proof and would contain any fire that could start inside. I will probably get one in the future but until then, I have been using this little metal tool box. In case of fire inside, flames could escape from four tiny holes at the bottom corners but it’s way better than a cardboard box. I always keep it on the garage cement floor.
No brain, no headaches.
mistercrash
Find all posts by mistercrash
