05.15.2009, 04:21 PM
Originally Posted by Nixpus View Post
Thank you for the feedback guys :)
I really dont want to place the motor in the "hight cg" position. So I'll order a 43t flux spur. Do you think the eZrun motor with heatsink/fan can fit the TVP's in flux style? It is a slightly fat lady
Good info about p/n 100905 - cheers!
Which ez run motor is it? The 36mm motors, or the big ole 44mm? You can take a cue from the flux and make a tvp for that side that has a "window" in it that will allow the motor to sit slightly outside of the tvp.
I did a savvy a while back (hv savage was the name of the thread, I think) and I managed to put a feigao lx can (36mm diameter motor) on a custom L bracket on the stock nitro engine plate and fit up to 18/47 gearing. That was with the stock tvps. It was a tight fit, but it worked well, I adjusted the mesh by sliding the L braket side to side as you would with the nitro engine.
