jzemaxx
05.15.2009, 06:52 PM
Yeah I want to try it during a heat. I see everyones Eagletree data quite often and part throttle setups don't seem to pull many amps, so I thought maybe a 6S turned down would give me results along the same lines. I didn't want to run the 6S geared down casue the motor is turning high rpms for a race. Almost 50K for a 20 min main or longer doesn't seem to me like a good idea. If I can run the lower EPA and run the motor at 30K rpms with high voltage...that would limit the amp draw even with the same gearing.
Serpent S811-E Tekin
Revo 3.3 BL- 1515 1Y
Mugen MBX6 NEU/MMM
Mugen MBX6-T NEU/MMM
Losi LST2.0 MT NEU/MMM
Losi 8T RTR 2.0 NEU/MMM
Losi 8T 2.0 NEU/MMM
Losi 8B-E 2.0 NEU/MMM
