12.23.2005, 03:36 AM
to anybody who has ordered this chassis you need to turn the differential so it runs backwards, if you run the spur to the rear. If you run the transmission backwards(spur to front) you will be ok. If you are running brushless you can change the wires to reverse rotation. but if you are running the titans you have to turn thr differentials over to reverse their rotation
