05.16.2009, 12:09 PM
In laymans terms...C rating is basically like the valve size on your garden hose. You can change how fast the fluid goes through it (Amps), and you can change the pressure behind it (Volts), but that valve is always only going to open up so far, thus only allowing so much water through....
