squeeforever
squeeforever's Avatar
05.16.2009, 11:13 PM
You might not need 30C. That would depend on the mah of the pack. And to answer your question earlier, the C rating refers to the cells. a 3000mah 30C is still gonna be a 30C cell no matter how many there are. Thats gonna be 90 amps, but if you put 2 in parallel, that will the 6000mah. Still 30C since the cells haven't changed, just the number of them. 6000mah 30C would be 180 amps. Get it? Its still 30C since thats what the cells are rated at. The amps just raises because the mah raises since there in parallel.
