05.17.2009, 10:53 AM
A couple things to check:
- Make sure your radio EPAs and trims are at default when you calibrate the ESC/radio.
- The braking in reverse is much harder than braking in forwards. Might be you somehow have the truck going forwards with reverse throttle input and vice versa?
- The setting in the link software is pretty self-explanatory. Start with a low value and increase until you find a setting you like.
