Originally Posted by Joram
Notice that with an oil bath, there is a lot of resistance....
Your motor won't like that very much...
Greetz,
Joram
With a small amount in the bottom of the tranny, just enough for the teeth of the lower gear to catch it should not add much drag, and will extend the life of the gears by 10-100s of times. If you filled it full it would add considerable drag.
Originally Posted by johnrobholmes
For low loads, delrin is indeed a good material. I should have been more specific. It is not the right material for a savage.
Definitely not the right material for any sort of high load or transient load situation that is for sure! Makes good skids on crawlers!
