superek4
superek4's Avatar
05.18.2009, 10:02 AM
If you are stripping the retaining screw on the adjustment nut, you are probably tightening it too much. The thrust bearing removes the twisting force from the nut in use, so it will keep its adjustment pretty well(tested it without a cinching nut, actually). You only need to "snug" the adjustment nut screw to retain the setting. If you use threadlock on it, use a very small amount. You must loosen this screw to make adjustments, and snug it back down when adjustment is complete(this is in the instructions that came with the unit and linked by brushlessboy16). :)
Yes but now I must figure a way how to remove d screw:(
My Sponsors
Hobbywing
ManiaRc
Acorn racing
UpgradeRc
Blackbeard RC
Team Hong Nor
Team RC Monster
MoosRacing
BocaBearings
SweepRacing
Tresrey USA
