MetalMan
MetalMan's Avatar
05.18.2009, 11:32 PM
Originally Posted by Urgeoner View Post
Nice work, u did all the machining urself? what tool do u use if so?
Did all the work myself, with a scroll saw for cutting, drill press for drilling, also chucked an end mill into the drill press for light milling.
Originally Posted by D8 Driver View Post
great CG, Looks strong.
Thanks
I'm not familiar with Solidworks. How did you go about "syncing" the other components? On that interface, can you select the direction of rotation and add a ratio between the first and second axles, then sync the second gear/pulley set to that second axle?
Originally Posted by anson View Post
Looks good.
Have you checked out the mechanical mates in solidworks? There is an easy option for gearing. You should be able to work it out.
The other components are "locked" together as mates, not synced together.
Sounds like I need to look into mechanical mates and add a ratio.
Thanks guys!
