anson
05.18.2009, 11:37 PM
Originally Posted by MetalMan View Post
Sounds like I need to look into mechanical mates and add a ratio.
Thanks guys!
That's is pretty much it. You might need to add a circle sketch to your gears for the pitch diameters which you can then easily mate together using the gearing option under mechanical mates. Just line them up, and mate, and all should be sweet. Then you are a step away from connecting the front, center and rear pulleys together with belts.
Solidworks is fun. :)
